What size oil restrictor?
Old Jul 15, 2005 | 04:49 PM
Mark C's Avatar
Default What size oil restrictor?
I'll be getting a Z06 pump for the forged shortblock, and I don't want to start blowing past the seals of the turbos.
What size restrictor(s) would you use for the feed to both, or the feed to each?
Thanks.
Old Jul 15, 2005 | 05:05 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
.035 is typical to run.
Old Jul 15, 2005 | 05:48 PM
red ws6 99's Avatar
Thanks.
If you have the Incon turbos, most of the turbos they used have orifices built into the housing. Mine difently did, it had a pin hole sized opening. Pull out the inlet adapter and you will be able to tell.
Gary
