Anyone running nitrous AND turbo?
first set up was a t76 and a camed 6.0. with that set up it took just a hair longer to spool than i liked so i gave it a small shot to get it spooled up. sometimes i sprayed up top too. i think i was near the limit of the turbo and power came easier with a small shot rather than more boost.
then i got a 408 and it spooled instantly with the t76. no need for a shot out of the hole, i couldn't hit it with full boost out of the hole or i would fry all 4. eventualy i hit the limit of the t76 and had to spray to get more power. a 100shot gave me about 140rwhp(edit 127rwhp) and 200rwtq.
turbos and nitrous go together nicely if you need help spooling or are out of turbo. if you dont need help with either of those things i would just go with more boost and avoid the extra complication.
He'll prolly post in here shortly for the 411 on it.
Was thinking of tryin it w/ a 50 shot on the FMIC whenever Speed Inc does my 6.0L iron block setup just for the cooling effect but i dunno. Cant do it now since my block is pretty much maxed as far as power goes
Kurt
Kurt
I am very curious about your setup, what all do you have in the engine to get it to handle that power and how much power are you able to squeeze out of the combo? I have seen pics of your car and it is one hell of a machine!
-Bryan
-Bryan
Here's a few links to get you started:
https://ls1tech.com/forums/showthrea...ghlight=casper
http://www.w2wpowertrain.com/t-Casper-2.aspx
Rick
The engine is fitted with a Callies 3.5 crank, Oliver 6.125 rods, Mahle 4.005 pistons in a iron 6.0 block. The car will be in Hot Rod magazine soon with a basic rundown of the engine. There is also a Magazine called Engine Masters that has a more in depth article coming about the engine.
The power was 1697hp @7500 rpm on a engine dyno with 30 psi. On the dyno the turbo's were surging above 7500 rpm so I did not run it higher although it was still picking up power. In the car we are shifting it at 88-8900rpm with the nitrous on and 32psi of boost. I think its making about 1850-1900hp in the car. The head gaskets are leaking on every run a small amount. We have some transducers on the cooling system now to moniter temp and pressure, hopefully this will lead to some improvements in head sealing.
We are planning on running the car at the track again real soon as it has a Bruno/Lenco in it now that should cure our trans issues.
I will be selling this engine in the wintertime if you know of anyone that races with a LSX engine.
Kurt
-Bryan
Thanks,
-Bryan
The engine does have steel caps and a W2W girdle system. The piston is a Mahle custom made for W2W. The headstuds are 1/2. The head gasket is copper with o-ring/reciever groove combo.
Kurt
Thanks,
-Bryan
Kurt
man, thats one sick *** setup. im hoping mine will put down half of that power...
