change oil before or after STS install
Old Jul 26, 2005 | 02:53 AM
HossinatorSS's Avatar
Default change oil before or after STS install
i'm getting my STS kit installed in a few weeks, but i'm due for an oil change now. does the sts necessitate draining the oil when tapping into the oil system for the turbo? or can i just change it now and it'll only lose a bit? hate to waste mobil 1!
Thanks!
Old Jul 26, 2005 | 03:30 AM
Wildman's Avatar
You should drain all the oil before tapping in.
Old Jul 26, 2005 | 03:50 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Just change the oil at the same time you do the kit. Since you don't actually have to drill and tap for the oil feed (sts gives you a replacement fitting) you don't have to worry about metal particles contaminating the oil.
