Why is TQ so inconsistant in FI setups?
Old Jul 28, 2005 | 12:06 PM
2000 Tran Zam's Avatar
Default Why is TQ so inconsistant in FI setups?
Sometimes I see setups with similar matching rwhp and rwtq, and at other times i see 100 or more rwtq then hp.
Is there anything in particular that affects it? maybe certain cam specs bleed of enough pressure to affect hp, but not tq?
Im not sure how its all connected, but its something interesting to examine...
Old Jul 28, 2005 | 12:08 PM
ddnspider's Avatar
have an example?that would probably be easy to show where the difference was....could be in efficiency,flow,cylinder pressure bleeding off like you said.could be alot of things.
Old Jul 28, 2005 | 12:13 PM
LSONE's Avatar
backpressure, turbo size, system restrictions, etc.
Old Jul 28, 2005 | 12:14 PM
sb427f-car's Avatar
SSU'S Vice Mod
Timing @ pk tq.
Old Jul 28, 2005 | 12:23 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Can you even get a good torque reading with a T400?
Mine's been like 650rwtq, I don't think that's the case.
Old Jul 28, 2005 | 12:31 PM
Below are three examples that ive taken screen shots of, just off of the top of my head.
granted one of them isnt even an ls1, but still FI is FI, at least i would think so.
Attached Thumbnails Why is TQ so inconsistant in FI setups?-hp1.jpg   Why is TQ so inconsistant in FI setups?-hp2.jpg   Why is TQ so inconsistant in FI setups?-hp3.jpg
Old Jul 28, 2005 | 12:32 PM
Originally Posted by sb427f-car
Timing @ pk tq.
cant you adjust for that via hp tuners or ls1 edit though?
Old Jul 28, 2005 | 12:51 PM
ddnspider's Avatar
ok for starters forget the 1st pic lets just deal with the LS motors....youre 1st ls motor is a basically stock motor with a small turbo(T66)...then you have brians 427C5R motor at the time that was S/C'd...2 totally different motors purposes builds etc.you need to find 2 people with the same motor or FI setup and and then you could see where the subtle differences could be,such as timing and IATs.
Armageddon's Avatar
...with cheese.
...lol he's probably referring to mine.
My undersized turbo has a lot to do with it.
Old Jul 28, 2005 | 12:52 PM
ddnspider's Avatar
no your turbo is bigger he's using a T66!!!
Old Jul 28, 2005 | 12:53 PM
ddnspider's Avatar
silberbullet 455/516 @ 7psi which is pretty good i think.
then brians C5R make 822rwhp forged and all
so 2 different ballparks
Old Jul 28, 2005 | 01:17 PM
Silberbullet are very good numbers for mods, im just saying i would think they would be within 20+/-.
brians car has like a 70 difference. How big of a role does a stall have to do with tq?
Old Jul 28, 2005 | 01:18 PM
Gosh, get a turbo with talons in it... /Napoleon
what size are you using again, the 76gts?
Edit: just saw the post of your gt70 in the for sale section
Old Jul 28, 2005 | 01:26 PM
LSs1Power's Avatar
I think the increase of TQ has to do with few things:
Main thing is back pressure created from Turbo. After that smaller manifold, smaller exhaust duration with lift than intake come to mind. Also the efficieny of the tranny especially in an AUTO. Some Nitrous cases make alot more TQ than a Turbo setup. I have noticed people gain more TQ over their HP with Nitrous when running through a full stock exhaust system which only means more backpressure. The difference between the HP and TQ numbers decreases when they run full exhaust system even though they are still making more power than before. Just my opinion.
Old Jul 28, 2005 | 01:34 PM
30th t/a's Avatar
i wondered the same thing. 99SS-T has the phamspeed t76 w/10 psi made 531rwhp/534rwtq
rob raymer's test car made 534/687 w/ 9psi open exhaust...look at that torque
Tiago made 615rwhp/613rwhq with 10psi (forged bottom end) stock heads & cam
all cars were bone stock everything. robs car had the ls6 intake.
Old Jul 28, 2005 | 02:03 PM
ddnspider's Avatar
why would a turbocharged stock 346 be close to a supercharged forged 427?
Old Jul 28, 2005 | 02:04 PM
ddnspider's Avatar
what turbo's were they all using?
Old Jul 28, 2005 | 02:20 PM
30th t/a's Avatar
tiago had a garret t-72, 99ss-t has a t 76 and robs kit had a pte-63
Old Jul 28, 2005 | 02:29 PM
sb427f-car's Avatar
SSU'S Vice Mod
Yes you can, I was just thinking a simple way to explain how someone has a car tuned in can affect the reading. Both might make the same pq hp, but different pq. tq and that could just be timing differences @ those areas of the map. In reality, there are TONS of reasons why.
Old Jul 28, 2005 | 02:30 PM
ddnspider's Avatar
robs car makes sense with the open exhaust.Tiagos was a custom setup i believe....the real questions is what exactly does each car have in there setup,im too tired to search...someone else do it an post and we can see the small differences.
