Anyone seen this head gasket
Old Jul 29, 2005 | 10:35 AM
427's Avatar
427
Tom,
They did not come in time for my engine. There is no current plan to install them at this time. I have two sets of S11154LS in stock. They are 4.155X.043 Titan series.
For what its worth, we never reuse cometics gaskets. The Cometic is a nice part. We consider them equal to the factory mls part.
Kurt
Originally Posted by tomulrich
These gaskets cost approx 85.00 each. They do recommend retorquing...as do most companies.
I would not reuse these gaskets.....I also wouldnt reuse cometics....I know they are reusable and can work fine but why chance it?
These gaskets do not require oring grooves in the head or block. No machining required. The o-ring is incorperated into the gasket.
They come in .43 .50 .62 .80 thicknesses. They also have popuplar bore sizes including 4.155.
I think I am going to try them ......there does not seem to be anything else out there other than cometics....which I have had experience with...and have to say I was not very impressed.
W2W......when do you plan on using these gaskets? any build coming up?
Tom Ulrich
Old Jul 29, 2005 | 10:38 AM
smokinHawk's Avatar
i have reused my cometics about 3 times, they weeped once, but it was probably toqued wrong or just to much cylinder pressure. after i re-installed them they havent weeped after it.
Old Jul 29, 2005 | 04:19 PM
parish8's Avatar
single digit dreamer
Originally Posted by smokinHawk
did you take a chunk out of the steel gasket or is it just weeping?
it was pushed out toward the exhaust. it wasn't leaking coolant and i didn't know it was leaking but the pic's show that it was about to go on me.
Old Jul 29, 2005 | 04:54 PM
NA$TY-TA's Avatar
Originally Posted by Brains
We reused Tiff's FlatOuts once, put 'em on right before the power tour. They had no problems sealing water, well until we detonated like crazy during some highway tuning Then they only leaked a tiny tiny bit, and we still put another 3500 miles on them to get home ... I'm pretty impressed with them, and we just put another brand new set on the motor.
Damn That says alot.......
Old Jul 29, 2005 | 05:00 PM
y2khawk's Avatar
IMO, if you don't need a special bore/thickness you can't beat the OE MLS gaskets. They seal properly, they're cheap, and they can take alot of abuse. And i'm in the habit of changing them regularly just because I abuse them
Mine saw high 20's to 30 psi all of last year. And i'm still running them this year, when it actually runs My target power/MPH will require north of 35psi this year.
Old Jul 29, 2005 | 05:12 PM
NA$TY-TA's Avatar
That says even more...... from someone who has been there done that...... on stock $60 MLS gaskets...............................
Old Jul 29, 2005 | 06:45 PM
y2khawk's Avatar
$17 each
Old Jul 29, 2005 | 09:51 PM
ddnspider's Avatar
when you say MLS is that adiff gasket then say ordering a Felpro head gastet?
Old Jul 30, 2005 | 08:54 AM
Bryan Wilkinson's Avatar
What do you guys think about this head gasket? Anyone used it or know someone who has used it?
I am looking to run 20-25lbs boost.
I know all the othe gasket companies out there.....please do not comment on them......just pros and cons and experience with the above gasket
Looking at 4.155 bore with .050 thickness....
Thanks Tom Ulrich
Yes, I have had one, but did not use it because the gasket was not the problem I had at the time. There are two different kinds that they make, they are about the same price as the commetic, excpet, they claim, no retorquing, they also claim that the design has the o-ring built in and they have been tested up to 42psi without failure. They also claim that they form better to the heads and block. The other requires you to o-ring the block.
Once a set of heads has been used for any lenght of time, the surface of the head will start to warp and everytime you take them off to replace the gaskets you are suppose to sand them down flat again.
You can verify this, by taking the heads wraping 200 grit around a piece of aluminum block and running it over the surface of the heads. These ICE titan gaskets allow you suposedly not to have to do this by better forming to the surface.
Old Jul 30, 2005 | 08:55 AM
MLS is a multi layer steel gasket, Cometic, and Felpro and GM all make one.
The ICS gasket is a copper gasket.
Old Jul 30, 2005 | 09:13 AM
parish8's Avatar
i haven't seen the felpro mls. the last time i went down to the local auto parts store and asked for some felpros they were the composite style, not mls.
Old Jul 30, 2005 | 11:54 AM
  #32
Brains's Avatar
I've got the Fel Pro's on my car, and they're composite..
Old Jul 30, 2005 | 12:38 PM
  #33
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm running MLS head gaskets like Harlan.
Old Jul 30, 2005 | 12:48 PM
  #34
ddnspider's Avatar
so you have to specifically ask for a MLS then...you cant just go to a dealer or an auto storre and say i need a set of 6ltr head gaskets or a set of Felpro's then right?
Old Jul 30, 2005 | 12:58 PM
  #35
parish8's Avatar
the auto store may not have any mls gaskets avaliable.
goto the dealer and ask for some 02 6.0 head gaskets and they should be mls. they may not even sell the old style anymore.
Old Jul 30, 2005 | 01:09 PM
  #36
tomulrich's Avatar
they actually tell you to retorque...talked to them twice...they told me the same thing.
the ICS pieces have the oring built in. They recommend a flat surface. These are no recommended for "issues with warping".
Has anyone actually run these......any problems...?
Tom
Old Aug 1, 2005 | 04:31 PM
  #37
HUGGER ORANGE SS's Avatar
Harlan.. I had no idea you put that much pressure to the stock MLS gaskets.. Looks like I'll be getting them for my measly 15psi..
clint
