oil return line
Old Jul 29, 2005 | 11:02 AM
94formulabird's Avatar
Default oil return line
I did some searching, and stil have some questions. I have a mocal oil pump going on my rear turbo for the return line. I have some options of where I want it. I dont want to drop the k member or tap the pan while its on there, so I was going to do the valve cover, but I read somewhere that sts kits come with a oil cap where the return goes right in there? Is that right, and if Im thinking correctly..isnt that the easiest. COuld you buy that cap anywhere? Where would you guys run it, besideds the pan. Thanks
Old Jul 29, 2005 | 11:10 AM
ON EDGE WS6's Avatar
The Pan...
Old Jul 29, 2005 | 11:31 AM
Blackbird's Avatar
all sts does is tap a stock oil cap with some fittings.
you could easily do the same.
Old Jul 29, 2005 | 02:35 PM
Would tapping into the cap work just as good...that would be easy, and I like easy
Old Jul 29, 2005 | 05:21 PM
Silver02Z28's Avatar
Tap the cap. It works for me.
