Turbo Exhaust
Old Aug 4, 2005 | 04:49 AM
REDTURBOSS's Avatar
Default Turbo Exhaust
What kindof exhaust are u guys running after the turbo? I want to run duals after the turbo if possible, does anyone know where I can get the best exhaust for a turbo application for our cars I just dont want to cheap out on the exhaust.
Old Aug 4, 2005 | 08:41 AM
REDTURBOSS's Avatar
Will A Regular Magnaflow Muffler Or Borla Muffler Be Okay Or Should I Get Racing Baffles? I Know Tha The Turbo Quiets Down The Car But By How Much?
Old Aug 4, 2005 | 08:50 AM
Snake Eater's Avatar
Are you still running cats? If so there enough to keep it somewhat quiet with a turbo also. The Neon SRT4's dont come with mufflers at all. Just a small resonator and cats.
Magnaflow would be your best bet on quality and price. The ultra flows would let the turbo spool almost like strait pipe and keep it quiet.
Old Aug 4, 2005 | 09:04 AM
Race-Prep's Avatar
Suspended Sponsor
I Personally think it would be a better idea to run a single exhaust as there will be no restriction/turbulence from the reverse y pipe you would need to run. If you need ground clearance and want a large diameter pipe then use the oval exhaust available from several companies out there. I can do either one totally mandrel bent (no kinks) for you if you need a good exhaust job and don't know where to go.
-Bryan
