thermocouple for incon
Old Aug 10, 2005 | 08:35 PM
SS2win's Avatar
Default thermocouple for incon
I'm looking to put a couple in close to the turbos. I remember having read somewhere that incon manifolds already have a boss cast in but I have not popped teh hood and looked yet. I found THESE on egauges dot com and thinking the last one on the list is for me. any tips or suggestions on what to get?
Old Aug 11, 2005 | 05:20 PM
SS2win's Avatar
eh... nobody has put a thermocouple on incon manifolds?
Old Aug 11, 2005 | 06:49 PM
SScam68's Avatar
not yet.....then again it isn't installed and might not be depending on what Jose conjures up.
Have you decided on a logger?
Frank
Old Aug 11, 2005 | 07:38 PM
red ws6 99's Avatar
No longer have my kit (SSCAM68 bought it) But there are 6 locations on each manifold if I remember right. There is a connection for each header tube and then two additional. Threads are metric. I would have gotten the connections from www.swagelok.com and the type-K thermocouples from www.omega.com.
I was looking at logger from this company but there a ton others:
http://www.picotech.com/thermocouple.html
Old Aug 11, 2005 | 10:28 PM
SS2win's Avatar
Thanks a bunch for the links red, the Omega site is what I was looking for. Industrial sensors, yeah. I have EFILive for logging.
Old Aug 12, 2005 | 12:23 PM
red ws6 99's Avatar
Just remember to get a reference junction along with the thermocouple, otherwise something like efilive won't work.
Old Aug 12, 2005 | 04:01 PM
SS2win's Avatar
Huh, I'll look into that but from what the manual says it sounds like you can connect a K type without doing anything else
The EFILive FlashScan interface is equipped with 3 separate inputs for capturing external data. The 2-pin terminal is a dedicated cold junction compensated k-type thermocouple input. The 3-pin terminal can accept up to 2 analog, 0V to 4.8V signals. Either of these two analog inputs can be used to log wide band O2 AFR data.
EDIT: Yep a CJC junction is temperature compensated so it should be acccurate.. thanx
