Belt issues???
Old Aug 11, 2005 | 09:35 PM
Packy's Avatar
Default Belt issues???
Ok, so I go to the track tonight to try and get a few runs in but everytime I launched my serpentine belt would fall off. The only thing that I can think of is my belt tensioner is going bad. It feels tight still. I just replaced my serpentine belt with a new Dayco Poly cog about a month ago. Anyone have any ideas as to what else might be wrong???
Old Aug 11, 2005 | 10:59 PM
SSmokin 01's Avatar
Mine started doing that after going to 10psi. I changed to the katech solid tensioner and haven't had any issues since. http://thunderracing.com/catalog/?ac...vid=3&pcid=113
When I was searching I came across a thread that said TR also sells a tensioner pulley with higher sides to keep the belt from falling off. It's not on the site, you have to call and ask for it.
Old Aug 11, 2005 | 11:13 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
First thing to do it play with the tensioner. You need a lot of 'tension' to keep the belt from slipping, and ultimately walking off. I run 18-21.5 psi and run a manual tensioner. You might be able to run a spring tensioner at 10-12 psi. But if you can twist the blower belt with your hand, like twist it 90 degrees, it's too loose.
I run Dayco Polycog belts too.
Old Aug 11, 2005 | 11:35 PM
Ferocity02's Avatar
Where does one buy Dayco belts? Are they better than Goodyear Gatorback belts? Thanks!
Old Aug 12, 2005 | 10:31 AM
Packy's Avatar
You can find them at Advance Auto parts.
PSJ,
My blower belt was fine. I have an ATI p1-sc kit. It was my serpentine belt that drives all of the accesories on my car that was falling off.
Old Aug 12, 2005 | 11:42 AM
LS1Tech Co-Founder
Oh. For that I would get the high flanged pulley from Thunder Racing, also known as the ASP "Larry" pulley. Going over 6500 rpms I had that problem too.
Old Aug 12, 2005 | 01:21 PM
Ferocity02's Avatar
I like how they're aren't any Advance Auto Parts stores west of Colorado... Yet they have several stores in Puerto Rico, but none in California...
