got a problem with my vortech...
Old Aug 22, 2005 | 10:51 AM
millionride's Avatar
Default got a problem with my vortech...
hey everybody, this is my first problem with my vortech in over 3 years so i can honestly say im happy it lasted this long with no problems. on friday i was out on woodward for the dream cruise here in detroit, and i was playing around alot. on the way home i felt the engine bog down and felt like it wanted to stall. so i pulled over and it went away so i drove home.
When i was driving home i was hearing a different sound coming from the blower it wasn't really whining it sounded like it was blowing air into the atmosphere. so i get home pop open the hood and the clamps that hold the aftercooler to the blower are loose and the aftercooler is just laying their not connected to the blower our the bottom tube that goes into the throttle body. what could of happened could the bolts have come loose or did i blow it off litterly. ive never heard of anybody having this problem. Now my SES light is on and i don't know if i did any damage to the motor or whats going on...any helpfull hints you guys can pass around? my motor has all stock internals. thanks
Brian
Old Aug 22, 2005 | 08:56 PM
Mike 01WS6's Avatar
Brian, time to take it down the street to Joe's. Sell that **** and get a Stenod Racing turbo setup pronto!
Old Aug 22, 2005 | 09:23 PM
GTOLarry's Avatar
You might want to check fittings from time to time. If they become loose over time it is indeed possible to pop them off under boost. Probably no damage. Just check all the hoses, replace as necessary and bolt back together.
Old Aug 22, 2005 | 09:41 PM
Inspector12's Avatar
TT-TECH Veteran
Yeah if the bypass valve didn't work it could have blown the pieces apart. This is my guess the plasic bosch things are ok but do fail. I would replace it and see what happens I don't think you hurt your motor at all. It would only cause it to go rich witch won't hurt much except the plugs. Good luck!
Old Aug 22, 2005 | 10:10 PM
thanks for all the good advise guys, yea i plugged everything up again, and the car ran fine, and today the SES light went away, so hopefully everything is cool. car is going to livernois this wednesday for a dyno tune. can't wait
yea mike, a stenod turbo would be great if i had the money, hopefully next year
thanks again
Brian
