Going Forced
To answer your question- you could quite easily lower your compression enough to keep your current heads, but it would be alot of work and money, IMO, I would just get bigger chambered heads.
Good luck! Last edited by 1bad2k2ta; Aug 23, 2005 at 05:23 PM.
Besides, cheaper isn't necessarily better. If you change pistons, you are pretty much committed unless you want to change pistons and rebalance, etc. yet again. With a head swap, you can always go back, or on to something different without disturbing the bottom end.
