Pin kit for a 6 rib P1SC?
I've seen posts on here about a pin kit for the ATI Superdampers and 8-rib Procharger crank pullies.
Can someone tell me if Procharger sells a pin kit that would allow pinning the Procharger 6-rib crank pulley to the stock balancer. Does a kit even exist?
Thanks for the help.
Brian
Kyle
Kyle
I currently don't have a Procharger. Just doing some research and making sure that I cover all the avenues before I start buying things.
Since the P1SC comes standard with a 6-rib I thought I would utilize the SDCE 6-rib tensioner and pin the Procharger crank pulley to the stock balancer. I also don't plan to run any more than 7 psi. Shouldn't this be sufficient? Any thoughts would be welcome.
By the way, because I live in CA I have to go with the P1SC to stay smog legal.
Brian
