9sec 93 octane setup?
Old Aug 28, 2005 | 02:14 PM
1BADAIR's Avatar
Originally Posted by eviltwins
No, I wouldn't be. I helped a friend tune his ford, it was a 8.5:1 compression 408, aluminum heads flowing 325/255, vic jr. intake converted to EFI, and a precision T76 GT-S trim. Couldn't run more than 12-13 pounds of boost on 94 octane or it would knock horribly, exhaust backpressure was right around 40 psi, and we were blowing header gaskets and seeing valve float from so much backpressure. That exact same turbo on my 347" 9:1 motor did an easy 16-17 pounds of boost on pump gas with similar timing, no knock, and it made a lot of power on pump gas.
On pump gas, I would be right. Ringing it out to peak boost, I would be right. You're choking off the turbine and the compressor on a big motor like that.
2001ws6 isn't wrong. He knows from personal experience from the combo he listed. 10.08 was in high heat on pump gas with low boost. The **** has been bumbed up for race gas now but the times are secret for now.
Old Aug 28, 2005 | 06:07 PM
CHRISPY's Avatar
8.0:1 compression
stock cubes (forged pistons/rods)
Decent heads/cam
D1SC pullied to give around ~15-17#'s on 93 octane
Should be between 600-675RWHP depending on head/cam configuration
9's should be possible at 3000 pounds on pump gas.
Keep the compression low ~8.0:1 and let the compressor flow the cfm for a given power level.
