quick FI question #2
Old Aug 26, 2005 | 06:11 PM
ty_ty13's Avatar
7 Second Club
Default quick FI question #2
what is not letting people run a higher compression with FI?
say i wanted to run 11:1 CR and 10#boost what would go wrong?
Old Aug 26, 2005 | 06:15 PM
foshizl's Avatar
From my understanding and i could be wrong... you can do that however you would have to run Race gas so you do not pre-detonate...
Old Aug 26, 2005 | 06:24 PM
y2khawk's Avatar
advance, CR, cylinder pressure, and octane are all ***** to turn with an FI setup.
More often, a higher pressure ratio will put a turbo/blower into a more efficient range of operation (ie lower temps after compressing the air). Being able to run at those pressures will often reduce the safe advance/CR you can run for a low octane number.
lower charge temp goes a long way And it's easier to make things live on pump fuel with a lower CR.
