pt88+408 dyno vid
Old Aug 29, 2005 | 03:10 PM
  #41
frcefed98's Avatar
Its a beautiful thing to see an LS1 truck hit 1011rwhp on pump gas
I loved the video of you smacking that liter bike from a standing start
Old Aug 29, 2005 | 03:26 PM
  #42
hellbents10's Avatar
LS1Tech Sponsor
Very nice indeed!
Old Aug 29, 2005 | 03:35 PM
  #43
Brains's Avatar
Originally Posted by dieselgeek
Jim's at work, figured I could answer this question so....
the MAF is still in place, but MS is speed-density so it's not used for fueling control. The intake is a stock truck piece, as is the TB I believe.
-scott
Hey Scott, did you see MSnS can now use a MAF (voltage scaled, ala Ford style)? These things tune so darned easily and so well in speed density as-is, but its definitely a nice option for guys with huge cams who don't want to mess with Alpha-N (or huge cams with forced induction).
The MegaSquirt is definitely up to the task, it works well, easy to use, and its stable. We had zero problems slapping one on the girlfriend's car and immediately taking it on the Hot Rod Power Tour. I'm using another on my LS1 Mustang project, but this time likely going to be running ONLY the MS, and no factory PCM
Old Aug 29, 2005 | 04:44 PM
  #44
parish8's Avatar
single digit dreamer
vid should be back up.
we saw 26psi peak but it quickly droped to 20psi for most of the run.
i took off the massair awhile back. might goto the track friday but i wont be cranking it "ALL" the way up, just some predragweek tuning.
stock truck intake and stock drive by wire throttle body.
i think it would do 800 on pump on the dyno but not on the street. as it is tuned now i think it will just barly do 800 on the street with the meth tossed in. have to add some race gas after that. i am running 2 nozles, a 15 and a 10 and the gain is turned up 3/4 of the way. then we tuned around the extra fuel just looking at the wideband and still shooting for a reported 11.5-1. i dont think i want to add any more meth just yet, going to play it a little safe till drag week and probably run a little race gas if 800rwhp isn't enough to get me to my goal of low 10's on drag week.
Old Aug 29, 2005 | 04:45 PM
  #45
parish8's Avatar
another note about he mega. we didn't use any nitrous but it has a killer nitrous control set up. it will add fuel for you, act as a window switch, wot switch, boost window switch(spooler).
Old Aug 29, 2005 | 05:58 PM
  #46
qqwqeqwrqwqtq's Avatar
See you there
Old Aug 29, 2005 | 06:45 PM
  #47
VINCE's Avatar
Shorty Director
Nice..
Old Aug 29, 2005 | 07:20 PM
  #48
parish8's Avatar
Originally Posted by INTMD8
See you there
hell yeah! see you there.
Old Aug 29, 2005 | 07:24 PM
  #49
JMBLOWNWS6's Avatar
Wow I just watched that. OMG Thats is sicks. I am suprised how much the stock fuel system can take with a dual intank setup.
Old Aug 29, 2005 | 07:51 PM
  #50
gnx7's Avatar
WOW! And thru a stock truck intake and TB..... I can't wait to see what that truck can do a the track!
Old Aug 29, 2005 | 08:07 PM
  #51
ta_silver_bullet's Avatar
wow that is insane. good luck at the track let us know some times........so what is the record for the trucks anyway in the 1/4 mile? just a curious question
Old Aug 29, 2005 | 08:50 PM
  #52
Wet 1's Avatar
Dave, what CR are you running with your 408? Also, how does the stock intack track (including TB and MAF) compare to the LS1/LS6 pieces?
Again, very impressive!
Old Aug 30, 2005 | 01:07 PM
  #53
dlevene's Avatar
Very cool!!
Old Aug 30, 2005 | 01:38 PM
  #54
LSONE's Avatar
do you have ytour engine specs posted up anywhere? Who amde it and the parts used? what heads? Just curious
Old Aug 30, 2005 | 02:44 PM
  #55
bluecamaroz28's Avatar
Cool truck..Great job..
Wonder why you should have knock if you are running low CR like 8.0 or 8.5!
Old Aug 30, 2005 | 04:26 PM
  #56
parish8's Avatar
cmotorsports put it all together and it has afr225 heads. there is a complete list near the begining of this thread.
Old Aug 30, 2005 | 05:18 PM
  #57
Tiago's Avatar
Parish,
can you estimate the gains the AFR heads gave you? Just want to compare...
Old Aug 30, 2005 | 05:53 PM
  #58
Silver02's Avatar
Saw the vids of your truck. Incredible. Are you running in 4 wheel high or did you eliminate the low range?
Old Aug 30, 2005 | 06:44 PM
  #59
turbo-max's Avatar
hot damn parish!
Old Aug 30, 2005 | 07:01 PM
  #60
smokinHawk's Avatar
what is your CR i didnt see it listed
