Will my SyTy turbo work with LS1?
The specs on the turbo are: 67mm P Trim wheel, 4" inlet / 3" exhaust, .70 AR compressor, .85 AR exhaust
The exhaust housing is custom made for Syclones/Typhoons and is designed to move the turbo away from the motor for better clearance. I was thinking that this may work on a stock cube LS1 with an exhaust housing swap for fitment and maybe a bigger AR so I'm not choking the motor at higher RPMs.
Thoughts? Ideas?
If it is going to be too difficult or this turbo is just too small, I'll sell it and get something larger.
Thanks in advance!
Tyler
'92 Typhoon
'95 240SX
Thanks for the info guys. When I was looking for maps I saw JZ97SS1500s post over on Supraforums - you are everywhere man
Tyler
