turbo selection
Old Sep 2, 2005 | 06:44 AM
Ari G's Avatar
Default turbo selection
I´m thinking turbochargin my engine,what turbines can go over 1000hp,when a turbo is suposed to deliver 500hp that is the overall engine or just the turbine?
stupid question I know
Old Sep 2, 2005 | 06:54 AM
smokinHawk's Avatar
that is what the turbo can support. so when you hook it up you will be able to produce that at most.
there are more things involved like pressure ratios as turbos produce higher output at higher presure ratios, which large engines may not be able to acheive, so if a turbo can do 500 HP you may not see that.
