about to install Powerdyne..few questions??
Old Sep 6, 2005 | 02:34 PM
HOSS's Avatar
Default about to install Powerdyne..few questions??
Yea, I know, not the best out there, but I got the head unit dirt cheap. The unit has been rebuilt with a new kevlar belt. Im not expecting anything huge from my setup...I was just wondering if I am really going to need some flex-a-lite fans or not, I can have my stock ones come on at a lower temp if needed...anyone know?
Old Sep 6, 2005 | 03:14 PM
frcefed98's Avatar
The stock ones simply will not fit with the powerdyne headunit and plumbing in the way.....unless you move the radiator foward quite a bit....chopping welding.
Its best to go with the FALs and have em come on as low as you can.
J
Old Sep 6, 2005 | 04:24 PM
HOSS's Avatar
thanks
Old Sep 6, 2005 | 06:46 PM
White_Hawk's Avatar
I had (2) 13" pushers and one 14" puller on my setup. Worked great, but it was like $500 worth of fans.
-Geoff
Old Sep 6, 2005 | 07:14 PM
1bad2k2ta's Avatar
-Geoff
Not to mention drawing 30+ amps.
Old Sep 7, 2005 | 10:26 AM
White_Hawk's Avatar
Now that you mention it, I think they were pulling 44 amps! I actually had the car almost overheat because I popped the original 30 amp underhood fan fuse. I also ran an Optima Yellow because at idle with the fans on I was drawing off the battery.
-Geoff
