information on you STS guys
Old Sep 11, 2005 | 04:50 AM
AntiVenom06's Avatar
Default information on you STS guys
did you install it yourself?
how long did it take?
any pics?
power gains?
how much boost does it make?
Old Sep 11, 2005 | 01:06 PM
CAT3's Avatar
Restricted User
My buddy Larry, had a friend help with the install labor and I was there for tech support (broke hand so no physical work). Larry is not the most knowledgable on the F body/LS1 parts Identification and not as mechanically inclined (but he can set up some badass aquariums for real!). Took about 9 hours, total on a lift (again I wasnt there but a total of 2 hours, and Dan probably 6 hrs).
I am still in the process of tuning his car, as most turbo builds go, there are a lot of other things to tidey up, traction, fueling etc, and this one is no exception. Set at 5psi for now, until I finish tuning, get the meth setup working. Then it'll be his decision to push the stock bottom or not.
Hope this helps. FWIW, if you are good with the F body and LS1 you should be able to install this in less time then he has. But here in Hawaii we like to screw around a lot...local time brah!
Old Sep 11, 2005 | 01:11 PM
boostedtransam's Avatar
Took about 3 1/2 hours to install, I made 475rwhp-494torq with 8psi and methenol kit. upgraded the valvue springs and everything else is completly stock.
Old Sep 11, 2005 | 02:54 PM
can you use long tubes with the system? Also is there anyway to get a muffler if I did use LT's so its not so loud?
Old Sep 11, 2005 | 02:57 PM
also is there a sts sponsor on his site?
Old Sep 11, 2005 | 03:04 PM
I'm installing some lts in a few days, we shall see how much louder it gets. I have heard it not much but we shall see. There is a sponser on the site or just call STS and they will answer all your questions.. ststurbo.com
Old Sep 11, 2005 | 03:21 PM
Finaly I have decided not to spray and go FI if I can use my LT's. Now I just need to know what cam to get with my heads, that will work well with FI.
