exhaust pressure ratio?
Old Sep 11, 2005 | 11:29 PM
LSONE's Avatar
Default exhaust pressure ratio?
I was looking around for a FI cam, and was wondering how you would come up with an exhaust gas pressure ratio. I dont actually have a kit yet (and i'm not sure which I will buy) So I was wondering what I need to look at.
Old Sep 12, 2005 | 10:13 AM
618HAWK's Avatar
Why would you want to know this? The only way to read EPR is to be able to measure the inlet pressure and exhaust pressure at the same time, which is a caculated average of both.
Old Sep 12, 2005 | 10:26 AM
LSONE's Avatar
How to select a turbo cam
Duration:
Duration is critical to a turbo setup since its probably the single most important event of a turbo motor (i.e. time valve sits open and closed). Since the air is being forced instead of drawn into and out of the combustion chamber, duration will be your largest variable on how that incoming/outgoing air is managed.
Duration when using a manifold or log design on most turbo cams is usually about 6 degrees more intake duration than exhaust duration (226/220, 240/234). This is mainly because a manifold/log design will typically see higher then a 2:1 pressure ratio in the exhaust ( as high as 4:1 with some logs). By using a reverse split duration this will somewhat help prevent from getting exhaust gas reversion.
Duration when using an efficient header setup with most turbo cams will usually be (230/230, 224/224) or better known as a dual pattern cam. The thinking is with the exhaust backpressure being only 2:1 you can leave the exhaust valve open a little longer then if the exhaust backpressure was 3:1 or higher. Also some of the new turbo designs produce a much lower backpressure with the advent of better flowing turbine wheels and housings which further decrease the total amount of backpressure created by the system.
i took that off of forcedinductions.com, but was wondering, if i was to use the phamspeed kit, what would the EPR be with the stock manifolds, or an incon kit, with twins and cast manifolds, compared to a kit like hi-flo or ptks.
