Sts Turbo Questions!
Old Sep 12, 2005 | 12:04 PM
bowtiebadass17's Avatar
Exclamation Sts Turbo Questions!
could anyone with an STS turbo system on an LT1 or LS1 tell me some pros/cons of the system and any problems experienced? i was thinking of getting one for my 95 Z28, thanks!!
Old Sep 12, 2005 | 05:01 PM
boostedtransam's Avatar
I have a ls1 and I like it. I have about 5000 miles with it and no problems. I dynoed at 390 rwhp-405torq at 5psi.. Got the methnol kit bumped it up to 8psi and got 475rwhp-494torq. The only thing I upgraded was my valvue springs everything else is stock.. Hope this helps
Old Sep 12, 2005 | 10:03 PM
exit's Avatar
are the valvesprings upgrade a must?
what supporting mods are a must?
I'm thinking brakes is definetly something to do....
Old Sep 13, 2005 | 01:17 AM
Race-Prep's Avatar
Suspended Sponsor
Fuel system, I.E. injectors, fuel pump etc. ,Tune, if you are smart a wideband AFR meter of some sort, and TIRES
Old Sep 13, 2005 | 07:49 AM
awesome, any cons to having an STS system, i've heard of oil pumps that are 2 loud any conformation or denial of that?
Old Sep 13, 2005 | 07:52 AM
and are LT1 blocks stronger than LS1s since they're made of steel instead of aluminum? will they stand up to larger amounts of boost?
Old Sep 13, 2005 | 12:23 PM
Devil's Due's Avatar
As far as the blocks go it really depands on the set up but the cast iron can be bored bigger. My STS has had a few problems mainly with an oil seal going out on the charge side of the turbo and oil misting in to the system. STS is sending me a new turbo to replace the one that leaks. Other then that its a great kit. I think the valve springs are a must, then eather a fuel pump and injectors or the methinol kit.
Old Sep 14, 2005 | 12:39 AM
Kaneman's Avatar
I have the STS kit and the main con is the location because if something is in the road you could tag it. The main con is rain if you get caught in a flooded area you could suck up water. Other then that I love the kit.
Kane
Old Sep 14, 2005 | 12:18 PM
how far can i bore out? would 396 be stretching it? or would a 383 be better?
Old Sep 14, 2005 | 04:53 PM
geegro05's Avatar
where was it spraying in your engine?
Old Sep 15, 2005 | 12:24 PM
first, exit and kane, very badass cars, i wish i could have a late model SS!! so sick lookin'. another question, how can i make dual exhaust if i have an STS turbo system? can i still have dual? i don't like the look if i only have 1 side of dual borla tips lol thanks for all your help!
Old Sep 15, 2005 | 12:34 PM
klw1313's Avatar
i can hear my oil pump clicking when i first turn my car on but after that it goes away. passengers never complain about it either. you can have some kind of exhaust fabbed up, a local muffler shop can do this easily. i just cut mine off 12 inches after the turbo and it just dumps, if u wnat go to www.sixtninecat.com click on current projects and kyles turbo z28 to check out the pics of my install. inly prob ive had with the kit is the turbo hangs from the existing muffler hanger and my comes off everyonce in a while and hangs crooked, i put it back in by hand and finally fabbed a clamp and made it stay. also my car is lowered one inch in the front and the downpipe drags occosionally, no damage though.
