V-9 Rated for 575hp? Is this too small?
Really looking for 600rwhp with a good tune (11.5:1 AF, 21-24 timing). This is my daily driver
Thanks
Travis
With heads and cam it should be able to do it.
I don't recommend running that cam with the sc setup. 21-24 degrees of timing is too much too run on a fi setup unless your running methanol.
you have much to learn young grasshopper.
read up in here, use the search and you too will become a master in the dark side.
