Victor JR Pics and specs..
It uses either a 78mm or a 90mm throttle body.
It is designed specifically for air only, not gas.
The runners inside the intake are longer, giving better low end torque.
Typically does not flow enough air for big cubic inch motors and high reving 346+ ci (over 7,000rpm)
Fits under stock hood/cowl area.
Above intake,
Uses a 4050 style Carborator flange.
Carborated design for air/fuel (presmog swaps)
Short runners (lower midrange torque)
Flows more air, good for Big cube, High reving 346+ ci and heavy boost applications.
Above intake,
29086 is bungs and fuel rails.
red90cobra, a 4050 flange spacer should fit it.
if it's anything like the GM/Wenger one, anything standard 4150 bolt pattern will fit
gaskets, spacers, elbows, throttles, etc. carb studs too
FWIW, my GM is still as cast. Works pretty good as is
will this work? and I'm assuming I want to get the 1/2in one?
Post #9 https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html
