Which single turbo for 650HP?
Old Sep 14, 2005 | 06:43 PM
brad8266's Avatar
Default Which single turbo for 650HP?
What is a good turbo that will get me around 650Hp in a single turbo setup that does not have a ton of lag? I plan on building my own setup and am a bit confuse on what turbo would work best for me. Also, are there turbos that have internal wastegate that would suit my needs. I would like to keep my car streetable as well. I will probably also spray it a little as well. Help is appreciated.
Old Sep 14, 2005 | 06:53 PM
Sandmann120's Avatar
An internal wastegate might not be the best idea for a lowehorsepower combination. Might not be able to control the boost at lower levels.
Less boost=more flow through wastegate.
What do you have in mind for your piping and intercooler?
Old Sep 14, 2005 | 08:12 PM
brad8266's Avatar
Not too sure yet. I checked a matrix that you can choose the proper size turbo. It said a t72 ar-81 would be good for 700-800hp, which is in the range of 650 to the wheels. Is this really a good size turbo for this app?
Old Sep 14, 2005 | 10:09 PM
boostedtransam's Avatar
a t70 will get you 600-700hp
Old Sep 14, 2005 | 10:19 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Run nothing less then a .96 A/R. I would personally go with a MP-GT45 if you are building your own kit.
Old Sep 15, 2005 | 06:26 AM
brad8266's Avatar
how long does a .96 usually take to spool up?
