Bypass Q
Old Sep 16, 2005 | 07:32 PM
SS LeadFoot's Avatar
Default Bypass Q
Is there a way to mount the Mondo bypass valce without welding it on to a pipe?
Old Sep 16, 2005 | 08:32 PM
DeltaT's Avatar
You don't weld the Mondo on - you weld its mounting flange on and the Mondo bolts to it with 3 bolts.
You could fabricate something that the Mondo bolts to directly. It is best to mount it either near the blower end or the throttle end.
Jim
Old Sep 16, 2005 | 09:07 PM
Ok do I need the flange then? If I cvan bolt the Mondo somewhere else then do I need the flange?
Old Sep 16, 2005 | 09:18 PM
DeltaT's Avatar
You do not have to have the flange. Vortech has the dimensions of the hole and bolt spacing in this document:
http://www.vortechsuperchargers.com/...dobypassim.pdf
Any competent machine shop will be able to use the drawing to make a mount for you.
I made a custom mount for my Mondo, but ended up using the flange as a spacer between the mount and the Mondo.
Jim
Old Sep 17, 2005 | 10:49 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
or just buy it from vortech like i did.
