Where to get AN Lines?
Old Sep 19, 2005 | 11:12 PM
67Firebird455's Avatar
Default Where to get AN Lines?
I just bought an oil restrictor that goes on the center of the turbo on the inline side that uses a -4an connection, where would I find a connector for this, and what type of line are you guys using? Not sure on the oil temperature actually going into and out of the turbo... Recommendations anyone?//
Old Sep 19, 2005 | 11:55 PM
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
Make your own line. You can buy the steel braided teflon line and -4 hose ends from aeroquip.
Old Sep 19, 2005 | 11:57 PM
NA$TY-TA's Avatar
Yep just like he said... order it from Jegs or Summit.....
Old Sep 20, 2005 | 12:06 AM
V8_DSM_V8again's Avatar
Go to a hydraulic hose shop that makes lines for hvy equipment.
Ask for a 1/4 NPT to -4an fitting...
I get everything done there..
They have every fitting imaginable and can make custom length permenant crimped SS braided lines... etc...
Old Sep 20, 2005 | 12:09 AM
383LQ4SS's Avatar
I have a ton of -4 Aeroquip and stratoflex AN lines. Some with 90 degree fittings some straight of varying lengths. I also have -6, -8, -10 and a bunch of -12.
The -4 an is rated to 3000 psi and is top quality. Let me know what lenght you need. PM me. These are directly off aircraft and in excellent shape and have been pressure tested.
