View Poll Results: What Supercharger should I go with?
Magnacharger
41
32.03%
Whipple
60
46.88%
Other (please explain)
7
5.47%
STS Turbo
20
15.63%
Voters: 128. You may not vote on this poll
Magnacharger vs Whipple
Old Nov 13, 2005 | 02:57 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If you want a complete bolt on kit, go with the maggie. If you can put up with more headaches and fab work to get more power, go with the whipple. As far as I know, whipple still doesn't have any intercooler solution, so you have to fab your own. However, since the whipple doesn't sit in place of the intake like the maggie, when you do fab an ic assembly you won't have engine heat soaking into your ic. BTW, order the sc without their crap electronics. Just get tuning software and put in larger injectors for yourself.
Old Nov 13, 2005 | 01:22 PM
04Denali's Avatar
Go with the magnacharger, I gained 115 RWHP with mine
Mark
Old Nov 24, 2005 | 07:19 AM
mistermike's Avatar
I wouldn't debate any S/C manufacturer's idea of what a correct tune is, or how to achieve it. They vary from fair to crap. Get a "tuner" kit, bigger injectors, and have a pro set it up on the dyno.
Old Nov 24, 2005 | 07:37 AM
whitt1's Avatar
The Magnacharger is a better kit for a dailey driven truck.I've run mine for 2 years now with no supercharger related issues.I actually like the twinscrew supercharger better,but the intercooler and attention to every detail in the Magnacharger kit make it a better overall package.
Old Nov 30, 2005 | 06:23 AM
300bhp/ton's Avatar
Originally Posted by Devil's Due
Eather one of the SC are good but I'd just make sure to stick with a roots style or twin screw. Stay away from the paddle type SC/blower.
WHAT??????????????????????????
A Roots style is a PADDLE. And a twin screw is totally different. Then there's a centrifugal which is different again.
_________________________________
To the original poster. I have no idea how good each kit is.
However IMO and many others too, the Twin Screw compressor is the best you can get. KB and Whipple use basically the same unit. It's a Swedish company called Opcon. Lysholm I beleive are know owned by Opcon Autorotor as well (according to the website anyhow). Yet Lysholm have been building twin screw compressors under license from Opcon for many years anyhow.
Basically a Roots blower isn't nearly as bad as many think. If you use it in it's designed range it is pretty good and will offer lots of low end grunt. At higher rpms they do tend to drop of abit as the efficency of the blower is not as good. So typically psi levels will not remain stable and will dip in the higher rpms.
Hence they don't produce the biggest headline PEAK dyno numbers. Under the curve numbers are actually very good.
A Centrifugal blower is basically a belt driven turbo. They have to spin very fast to produce boost. A PD blower like a twin screw or roots will produce lots of boost in low rpm conditions. A Centrifugal will NOT. As engine rpms increase so does the boost. Centrifugal compressors are the most efficent and will produce the best PEAK numbers. However their under the graph stats will be comparitively weak, even compared to a Roots blower.
So if you want instant grunt roots is better, if you like WOT driving and want to be bouncing off the red line with maximum PEAK power then the centrifugal is a better bet.
EXCEPT:
That a twin screw unit, will produce the same low end grunt as a roots (not better, but certainly as good). And it will remain efficent at high engine rpms too. So it offers the best of both worlds. The low end roots style grunt and the high end centrifugal style PEAK power.
The centrifugal is still the most effiecent however and WILL on a like for like basis produce the highest PEAK numbers. But since when have PEAK numbers meant the fastest car/truck, espcially on the street. What you want is instantly accessable grunt no matter the gear or the rpms you are at. Only a twin screw can offer that.
A Twin Screw Compressor produces more power, more of the time than any of the other alternatives.
Roots = high boost to begin with which DECREASES as engine revs raise.
Centrifugal = low boost to begin with which INCREASES as engine revs raise.
Twin Screw = high boost to begin with which remains CONSTANT from idle to red line.
IMO for any street car:
1st choice - Twin Screw
2nd choice - Roots
3rd choice - Centrifugal
The quality of the available kits however is a totally different matter.
Old Dec 16, 2005 | 11:27 AM
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
Add one of these to your Maggie and see what happens
https://ls1tech.com/forums/forced-induction/422941-magnuson-mystery-part.html
Old Dec 17, 2005 | 11:14 PM
digitalsolo's Avatar
I've grown up around blown Top Fuel bikes, and I will tell you right now that a roots based blower does not TOUCH a twin screw in efficiency. Max potential a whipple will go a LOT futher then that mag will. You need to size properly though.
Old Dec 18, 2005 | 08:55 AM
unit213's Avatar
Administrator
KB (twin screw) owner here. Go with a Whipple. Forget the Magnacharger.
Old Dec 19, 2005 | 05:06 PM
Andy's Avatar
Is there an intercooler out for the whipple yet? I didnt think they made one.
Old Dec 28, 2005 | 12:03 PM
Third Gear's Avatar
My vette came with a Magnacharger and I love it. Although I'd definitely upgrade to a twin screw if the KB unit turns out to be good. I don't think Whipple is coming out with anything at all. They have that monster 3.3L blower for sandrails, but I don't know why they don't have anything for LS1 cars!
Old Dec 28, 2005 | 12:14 PM
white2001s10's Avatar
Earlier this year at the track, I saw a new Z06 with the magna run a 13.0 flat @ 119 MPH
Later a stock Z06 pulled up and went 12.2 @ 114 MPH
Hey now don't jump on me! I'm only reporting what I saw.
I know that all magna users aren't going to have such poor results.
Obviously neither Z06 owner could drive
I voted whipple.
Old Dec 30, 2005 | 10:05 AM
  #32
VX 255's Avatar
Not F body but GTO
http://starrperformance.com.au/displ...35321390-1333/
Running this intercooled whipple with boost up grade and water injection on my 383 in a Holden SS.
Old Dec 30, 2005 | 11:34 AM
  #33
Steel Chicken's Avatar
I voted whipple.
im sure driver skill had nothing to do with it either
sorry you said that already heh
Old Dec 30, 2005 | 05:08 PM
  #34
aja342's Avatar
registered user
It scares me just thinking about how much the Starr system would cost to get it here.
Old Jan 10, 2006 | 01:14 PM
  #35
insane amounts of money
Old Jul 20, 2006 | 10:01 PM
  #36
LSxChevelle's Avatar
I say check out the Kennne Bell...
www.kennebell.net
Old Jul 30, 2006 | 05:24 PM
  #37
UNDERR8D's Avatar
I HATE my Whipple!!!! Will never buy another one, thats for sure!! Customer service sucks!! Electronics suck!! No Intercooler!! Oh ya and customer service really sucks!!
There is no re-sale value for the whipple kits if you ever change your mind or want to up grade.
Old Jul 30, 2006 | 06:01 PM
  #38
2005suburban's Avatar
I had a Whipple Charger on my 03 silverado..
Best mod to date!!!
And you dont have to pay 4000 dolllars for it...
You can find them used everyday... for around 2000 dollars.... Injectors for 200.. Then your ready to go.....
I would buy the whole kit... You dont want the whipple electronics, there shitty....
I ran 8.5 lbs for around 6 months with NO problems....
You can always get a meth kit.... You dont neccesarly need the intercooler!!!
Just my opinion!!!
Although Magnacharger makes a GREAT kit... The price is Way to High for me...
STS would be the way to go if you are wanting to turbo charge.......
PM me and We can talk!!!
Old Aug 30, 2006 | 05:28 PM
  #39
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
The kenne bell looks interesting. Especially how they have upgraded most of their kits to a newly designed blower. Most feature larger displacement and the intercooled kits for trucks are said to be coming soon.
Last edited by Beaflag VonRathburg; Aug 30, 2006 at 05:29 PM. Reason: fixed spelling
Old Aug 30, 2006 | 05:36 PM
  #40
sleek silverado's Avatar
KB makes a 2.6 which would be fun on a 6.0, but I think the Radix has plenty in it to support a 4.8.
