Any interest in 352cid Long Block for BOOST?
- Stock Crank
- Ross Forged Pistons (9:1)
- Lunati Pro Mod Rods
- Arp Rod Bolts
- Clevite Bearings
- ARE Hardenend Head Bolts
- Ported/Polished Heads with Manley Stainless Valves (stock diameter)
- Comp Hardened Push Rods
- ARE Modified LS6 Oil Pump
- Iron Block Bored to 3.910
- Total Seal File Fit Rings
- Rods shortened .006 for zero deck height
- Main Caps recently align honed
- Engine has less than 1000 miles since refreshing
- Bottom end balanced
I'd prefer to keep my cam and springs, but could add them for +$500. Cam is Comp grind (221/227 114lsa .561/.569) and springs are Comp 918s.
I have dynoed the engine and it made 356rwhp and 379rwtq NA. Before refreshing, it made 510rwhp and 605rwtq with the turbo setup. Turbo is gone now and I'm looking to build a new motor for N2O (something with higher compression).
I'm looking to get $6500 (I will ship it) and core long block (you ship to ARE). Email if interested.
I really only need a block, heads, and crank. I should be able to pick that stuff up for the $1000 difference.
