Car breaking up on top end
Old Sep 26, 2005 | 02:07 PM
SSprayn's Avatar
Default Car breaking up on top end
Recently I blew both head gaskets on my car. I ordered new head gaskets and they were replaced, while doing that ew went ahead and replaced the opti spark since it was looked rusted and like it was about to crap out. After everything was back together we put to car on the dyno to make sure everything was in tact and running properly.
The car now will only pull till 5200-5300 and starts going crazy. It will not even make it to 6K. On the dyno you can see the graph looks like someone on a heart monitor lol. My first thought was it had to be the opti, but the shop insisted that it was brand new and had to be something else, so we have went through everything since then. The car has a T trim making about 11 psi.
Anyone have any idea what it might be or do you think it was my first guess of the opti being bad out of the box??? Any help is much appreciated
Old Sep 26, 2005 | 02:25 PM
Tiago's Avatar
have youswapped the coil?
Old Sep 26, 2005 | 02:34 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
if i remember corectly someone else had that exact problem,and they put in a stronger aftermarket opti and it fixed everything,ill see if i can find the article and post it for you
Old Sep 26, 2005 | 03:11 PM
Zombie's Avatar
Did you change the plugs recently, if so did you gap them correctly? I'm having trouble blowing out the spark at 13psi with a .031 gap, time to close them up to .025.
Old Sep 26, 2005 | 03:16 PM
will62085's Avatar
what valve springs are you running? i used to have the same proble, right at 5300 power would drop 90rwhp before the car hit 5400rpm, i replaced opti with a dynaspark and same thing, turns out it was valve float caused by crappy spring shims
Old Sep 27, 2005 | 04:44 PM
SSprayn's Avatar
The car has already made 650 before with the same valves and all. We checked those and they are fine, no valve float.
We have tried a new coil, pcm, 2 sets of wires, 3 sets of plugs and hours of tuning.
The opti that we had on the car that was just taken off was the one that made 650 and it was a gm opti, so I shouldn't need to go to a different opti, I think I just got a dud out of the box.
Old Sep 27, 2005 | 06:39 PM
95zpro's Avatar
I'd check the opti(you can get a bad one out of the box). Also don't forget that since you had blown head gaskets it would probably be a good idea to replace your oxygen sensors(coolant can foul these real easy) and I would double check for any leaks in your sc piping & intake manifold!
Old Sep 28, 2005 | 09:46 AM
blackz93's Avatar
I've seen this also, Brandon!
Old Sep 28, 2005 | 09:50 AM
mahhddgtp's Avatar
I am a newbie, but why can't you throw the old opti back on and see what happens?
Old Sep 28, 2005 | 10:00 AM
Race-Prep's Avatar
Suspended Sponsor
Opti-Spark=Problems I have seen this many times, likely it is the opti, they are a real problem!
-Bryan
Old Sep 28, 2005 | 10:15 AM
blackz93's Avatar
Opti's are weird. My car still has the stock one with 265,000 miles!! No problems so far!
Old Sep 28, 2005 | 01:34 PM
SSprayn's Avatar
Hopefully replacing the opti will do it. I should find out in a couple of days.
Old Sep 29, 2005 | 05:45 PM
SSprayn's Avatar
OK so a new opti was tired and nothing. Its not quite as bad but the car is still down a good 50 hp and the bad thing is that this is with the aftercooler using ice as well and the numbers before were w/o. I honestly don't know what to do with this thing.
Old Sep 29, 2005 | 07:20 PM
mahhddgtp's Avatar
Sell it to me. I will suffer with the 50hp loss...
Spark gaps?
Old Sep 29, 2005 | 08:12 PM
will62085's Avatar
is it a sudden loss? or 50 hp loss all the way across the power band?....your sure nothing changed in the valvetrain? still think it sounds like valve float...
you have a data log of it? be interesting to see if your getting any kind of knock, maybe somethign is causing false knock and your pcm is pulling timing?
Old Oct 2, 2005 | 10:05 PM
SSprayn's Avatar
Its just a sudden loss. Everything else seems to be online up until 5300 or so and then it will not make any power past that.
Any possibility of the converter failing?
Old May 25, 2007 | 12:34 PM
aggiez28's Avatar
what did it end up being?
(yes i know this is an old thread)
Old May 25, 2007 | 03:44 PM
SSprayn's Avatar
Bascially the stock PCM wasn't up to the task for the power the car was making and the fuel that it needed. Just had to go back and keep tuning until it got as good as we could. A fast system, or big stuff would allow alot more out of the car esp if a larger head unit where used on the blower.
Old May 25, 2007 | 03:47 PM
aggiez28's Avatar
how good was that? did you have to tone things down to get it to run right?
Old May 25, 2007 | 03:53 PM
SSprayn's Avatar
we pulled a little timing out of the car and had to try a few different settings with the gaps on the plugs. Also did end up having one bad plug wire that was replaced and that did help some now. The car now has a slight miss at part throttle around 3500 rpms on rare instances. Guess it has to be rpm/throttle combo to find it.
