Procharger Pulley Specs?
Old Sep 26, 2005 | 10:10 PM
TrakDay's Avatar
Default Procharger Pulley Specs?
I am in the market to put a 408 with a set of 245cc ET heads on my D1 powered car. I am wondering what people are getting for boost with the different pulleys? Any help would be appreciated!
Thanks
Old Sep 27, 2005 | 03:35 PM
TrakDay's Avatar
anyone?
Old Oct 8, 2005 | 09:53 PM
CountryMuzicZ28's Avatar
bump for a friend
Old Oct 8, 2005 | 10:01 PM
J&J Speed Shop's Avatar
Depends on how fast you want to go, I would suggest you build or buy a turbo kit. I did a complete build for a customer of mine, Forged stock displacement, AFR 225cc heads, and the max it will see is 12-13 lbs. spinning the D1SC to it max impellar RPM
Old Oct 9, 2005 | 06:54 AM
EPP's Avatar
EPP
It really depends on what camshaft you select. A cam with a 112 LSA-114 LSA is going to bleed out more boost than one that has a wider lobe separation. We got an easy 14 psi of boost with a 395 ci, Patriot LQ9 heads and a Lingenfelter GT2-3 camshaft. This wasn't with the smallest pulley we could of put on it either, as it wasn't at max impeller speed. Granted, the Patriot stage 2 heads were no match for AFR 225's, but the difference in a decrease in built boost would be negligible. Bob
Old Oct 9, 2005 | 08:31 AM
Caveman's Avatar
10 & 11 Second Club
Thanks
This will be cool to see someone finally build at fast setup for a GTO. Although for the already heave *** GTO you might be better off going with a 402 LS2 motor and save the 100lbs of an iron block.
Old Oct 9, 2005 | 09:08 AM
PHiL2's Avatar
Just build your bottom end.
Old Oct 12, 2005 | 02:29 PM
You can design a camshaft on a 114°LSA that has no valve overlap therefore no boost is bleed out. Which is what I did for this car. I really don't see how you are getting 14 psi on a large cubic inch motor unless the heads flow like crap or you have a very restrictive exhaust system. When it is all said and done boost # really doesn't mean much it is RWHP that speaks. This combo:
J&J Stage III forged bottom end 9:1 compression stock displacement
J&J custom blower grind camshaft
AFR 225cc heads out of the box
ATI D1SC kit with twin coolers & SDCE tensioner kit 3.7" pulley
1 3/4" long tubes, custom dual 2.5" exhaust high flo cats
Boost is between 8-9.7 psi
Car made 630 rwhp and your grand mother could drive it to church
What did the large cube engine make?
 Michael S. Palmer
Old Oct 12, 2005 | 03:33 PM
TrakDay's Avatar
How do you think that setup would do with stock heads?
Old Oct 12, 2005 | 09:14 PM
Honestly I don't have alot of experience with stock heads on these type of combos. We are a race engine builder/machine shop so all of the forced induction cars we do have full built upper and lower ends. Off the top of my head I would say at least 100-125 hp less rear wheel
Old Oct 12, 2005 | 10:38 PM
TrakDay's Avatar
ouch... My car is making 550rwhp on the stock bottom end and stock heads at 8.5psi at 7k rpms, as it is now. I was thinking maybe build the 347 and keep the stock heads with more boost, but that 408 still lingers as a nice option as well. Just a lot more to go with a forged 408 than the 347...
Old Oct 12, 2005 | 11:55 PM
Yeah well there are many factors. Peak HP doesn't matter as much as area under the curve and a flat torque curve. 7k rpms is alot on a stock bottom end. I tend to not set blower cars to turn big RPM cause if setup right it is not needed. This previous car had 630 rwhp from 5900-6200 rpm, and is very far from maxed out yet, but the owner can barely hookup the power he has now, so he is coming back in springtime for phase 2 of the project.
