OK so ive got this miss..........
Old Sep 29, 2005 | 10:12 AM
417 Motorsports's Avatar
Default OK so ive got this miss..........
And just recently started after i ran some race gass from out track one night. Its real bad when the motor is cold but after letting it run for say 10 mins it clears up and is not near as bad. Ive changed plugs twice and is seems to help but its still there. Now what gets me is that if its cold its got like a dead cylinder it seems but if you bring it just into a little boost it clears up Now after it gets warm and your driving it at lower speeds it has a intermitent miss but at cruising (2300 RPMs or more) its fine.. no miss clean smooth piulls hard ect.... IM LOST tell me what ya think.
Blake
Old Sep 29, 2005 | 11:01 AM
Reckless's Avatar
Super Moderator
Are you still running GM O2 sensors? Is the fuel leaded or unleaded? If it is leaded, you have likely fouled the sensors and this causes poor running at idle and part throttle. At full throttle, the O2 sensors are left out of the equation, so this is why it clears up under throttle. That's my guess based on the info.
Old Sep 29, 2005 | 11:54 AM
RealQuick's Avatar
Sounds like a plug wire/ignition issue. Does it feel down on power?
Old Sep 29, 2005 | 06:41 PM
Yes the gas is leaded but when i put it in the o2s were already bad... so after is started to miss and that gas was gone i replaced them... still there changed the plugs... fixed for 3 days then its back.... it really doesnt feel down on power.. but damn it gets on my nerves! if i rip on it it will clear up for the most part but someties pops through the exhaust so im thinkin its spark related and the unburn fuels just hittin the hot manilfds and popin....
let me know your thoughts please
Old Sep 29, 2005 | 09:19 PM
Blown SS's Avatar
Weak valvesprings ?
Old Sep 30, 2005 | 07:22 AM
RealQuick's Avatar
The same exact symptoms were on my step bro's 5.0 mustang. It ran great for 1.5 years then started popping occasionaly after a hard aceleration. 1 year later I finally get him to the dyno and his A/F turned out to be in the 15's @ WOT. Dont know how it got there, but it did. We richened it up, gained significant power/tq and no more popping. Might be worth checking your A/F again if possile.
Old Sep 30, 2005 | 04:38 PM
ill put the wide band back on it sat.
