Help with Turbo and Intercooler Sizing on 370ci
Currently I'm running 9psi with a WOT AFR of 12.1:1 running 100% meth (10GPH @ 4psi+). Running 15-17 degress timing. Haven't had this combo dynoed, but it pulled a 12.7@117 last time at the track, with 10* of timing. Car is a 6spd with a Ram Powergrip HD clutch.
Over the winter I of course want to do some more work. I know my injectors are going to need to be replaced with larger units, I'll probably go to 60lb/hr. My turbo are has to be getting inefficient at this boost level, and I know the motor can handle much more. I am still running the stock fuel pump too, I have yet to decide on what I'm going to do there. So here are my questions:
1.) Which turbo would work well overall for this size engine? Keep in mind I don't want it to be a "only spools at 5k, top end only" car.
2.) Cam. Is this relatively small cam holding a lot back? What else might I look into?
3.) Intercooler. I am going to be putting an intercooler in the car over the winter. Are there any writeups on helping with the sizing of the I/C core? I don't want to shell out $1k for the STS I/C when I know I can fabricate something else cheaper myself.
Any other suggestions? I don't really have a 'goal'. Faster the better. I know if I could drive the damn thing, it has a high 11s pass in it as it sits.
Let me know what you think.
Thanks
-Adam
what are the specs on the stock cam? people have made some pretty good power on the stock ls1 cams.
as far as intercooler, i dont know how much room is available in the front of a new goat, but a OBX unit would be an excellent choice for the money, less than $300 gets you an intercooler capable of supporting 800+HP a 24x12 in either a 3 or 4 inch thick version should be more than enough...look on ebay for the obx units, or a similar unit can be found here www.vsracing.net
TE-60 is a small center section turbo.... TE-63 is where large center section turbos start and can handle much more power. 6.0 litres worth of air will provide plenty of airflow to spool a T-70 quickly.
T-70/72 would be a good choice..... you should try upgrading your fuel pump NOW to maximize what you have. T-60 is on the small size for a 370ci motor.... we would run those on 231ci GN's without even thinking twice about it.
T-70 turbo, upgraded fuel system (pump/injectors), methanol or alchy injection and retune. Your car will fly. Plan on a new clutch as well if it isn't upgraded already.
