gear ratios and turbo
Old May 18, 2002 | 06:36 AM
nostromo's Avatar
Default gear ratios and turbo
I have an M6 with 3.42 gears now. What effect does changing the gear ratio have when you're running a turbo at low boost? I know it puts you in your rpm power range faster but does it have any side effects besides that?
Old May 18, 2002 | 07:51 PM
SS00Blue's Avatar
Default Re: gear ratios and turbo
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by nostromo:
<strong>I have an M6 with 3.42 gears now. What effect does changing the gear ratio have when you're running a turbo at low boost? I know it puts you in your rpm power range faster but does it have any side effects besides that?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You're running the right FI for a high (numerically low) gear set! A turbo has gnarly torque numbers, even at low boost. The 3.42:1 gear is a good choice. It'll get you out of the hole, with the prodigious torque, and still leave a ton of room for the top end charge. It also is a gear with particularly thick flange material. In a stock differential, this is a bonus.
I'm keeping mine, as suggested by Rob at LS1 Motorsports.
SC
Old May 18, 2002 | 08:06 PM
VINCE's Avatar
Shorty Director
I am keeping mine too.. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old May 19, 2002 | 04:16 AM
nostromo's Avatar
cool. thanks for the info. Ill stick with my current gears then.
