first atap runs with new motor
Old Jun 4, 2002 | 09:02 PM
cablebandit's Avatar
Default first atap runs with new motor
I finally got the 50# injectors liveable and HAD to do some WOT bursts at my favorite spot. I dumped the timing to a flat 13 degrees. If I get KR...too much timing isn't the problem <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I will work it up and into a good curve as time progresses. I was very pleased...last run I logged maf flow and got 56.55 lb/min at 4900 rpms. Dunno if it woulda gone any higher as thats where i let off the gas in 4th gear but that's a good start. This was done on 4.5-5 psi. Tomorrow I will start tuning the idle/part throttle a little and hope to see the track/dyno soon
Old Jun 4, 2002 | 11:44 PM
Blackbird's Avatar
Default Re: first atap runs with new motor
yeah!!!!
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jun 7, 2002 | 02:40 PM
Amazingly i have somehow lost 10 lb/min airflow and you can damn sure feel it as well <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> I knew things had started going too good.
Old Jun 7, 2002 | 03:55 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
hmm check for leaks. Man those are some big injectors man <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> . Hope you get it all figured out. Did you change anything in the programming from the last time?
Old Jun 7, 2002 | 07:30 PM
I'm getting it I THINK...read my post above....a new direction in tuning...basically back to how the turbo regal guys tune
