can i move my MAF to after the blower?
Old Jun 9, 2002 | 10:59 PM
parish8's Avatar
single digit dreamer
Default can i move my MAF to after the blower?
i am thinking about trying to set up an intercooler, if i do then it would be a good time to move my MAF to after the blower and after the intercooler, then i would have acurate IAT and i could use that to reduce my timing when the IAT gets too high.
can it take boost? can it take heat? in ls1edit the chart only goes up to 90deg c, about 195deg f. will my IAT be over that most of the time so it wont help? i have no idea what my actual IAT are under boost, it would be nice to know. is there a sensor that i could just tie into the intake after the blower and leave the MAF right where it is at? what are the 4 wires going to the MAF? 2 for MA? 2 for IAT? wouldn't that be nice
Old Jun 10, 2002 | 12:08 AM
y2khawk's Avatar
Default Re: can i move my MAF to after the blower?
Yes, it'll take boost
Yes, it'll take heat
Non-intercooled you will peg the IAT, w/ a cooler you should never really see more than 150°F. That is if you have a decently sized cooler and you not over working the whipple
Old Jun 10, 2002 | 02:11 PM
chasgiv3's Avatar
I run mine after the Intercooler. I also placed my IAT sensor in a bung on the Intercooler. Allows me to see intercooler temps when I log with Autotap.
Old Jun 10, 2002 | 06:48 PM
parish8's Avatar
where is the IAT sensor? i thought it was part of the MAF, if i can get a sensor that i can plumb in anywhere then i wont worry about moving my mass air, just the sensor.
Old Jun 12, 2002 | 09:13 AM
bgreen's Avatar
One of my TurboBuick buddies has setup his GN as a blowthru MAF setup, using an LS1 based MAF with Translator. Works great, better spool up, and he claims his drivability has improved even.
In theory, the airflow should be a lot less turbulent, and straighter if setup correctly.
Just thought I'd throw that experience out there.
Brian Green
89 TTA
01 Jeep TJ
Old Jun 14, 2002 | 10:27 PM
slow's Avatar
mkae sure you have lots of straight pipe before the maf.
Ryan.
Old Jun 14, 2002 | 11:55 PM
Ryan23silverado's Avatar
parish8:
Intake air temp. sensors are part of the MAF on trucks. On LS1s they are seperate.
Old Jun 14, 2002 | 11:59 PM
parish8's Avatar
any idea if i could get one from an f body to work on my car, i am not worried about finding a place to mount it just the electrical part
