Dyno Numbers
Next time I am going to spin the engine higher. Erik says the bottom end will hold to 7500
But I will probably just take it to 6500 or when my power drops off.
Where is your motor?
i think you owe me a
for me getting us the deal we did!lol my motor is waiting on the pickup tube i just sent out the other day,then when they finish the heads and bolt them on and setup the HS roller rockers im ready to go and they can ship it to me.the heads are whats the hold up now. but if you made what you did at 7#s im getting VERY excited to see what ill do @ 10-15psi
i think your numbers are great!i cant wait til mines done.Last edited by ddnspider; Oct 4, 2005 at 07:44 PM.
i think your numbers are great!i cant wait til mines done.read the dyno section....the majority of people disagree with you from their experiences
Its too bad the other guys backed out. It was a great deal.
I can't wait to see what you will put out on 10#. I have to figure out how to get there. But for now, I am pretty happy
im still amazed Eric said its good to 7500rpms!
High 6000 rpm range easy but that’s more the valvetrain. I don’t know what kind of valvetrain setup you are running but the shortblock can go as high as you want with stock oiling (7500 for short duration probably).
Erik Koenig
Erik Koenig
Make sure you have enough tension and are not getting belt slip.
On a 370ci motor with stage III heads and a decent cam the 3.4 made 14psi I believe it was and 687 rwhp. That was a D1 blower though.
It's either slipping or you have a leak somewhere if your only seeing 7psi IMO. I know the P1 is the little brother but it should make at least 11 on that motor I would think.
