how to control boost spike
Old Jun 17, 2002 | 08:49 PM
cablebandit's Avatar
Default how to control boost spike
I am running 9 psi now on what I think is a 8.5:1 motor now. My problem is it spikes to 10-11 psi and then settles back down to 9psi. I hope to run more boost soon but don't want to overboost with a spike. What's the best way to control spike?
Old Jun 17, 2002 | 11:22 PM
2bseen's Avatar
11 Second Truck Club
Default Re: how to control boost spike
can you overboost a powerstroke.
Old Jun 17, 2002 | 11:30 PM
AlonzoVersion 1.0's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cablebandit:
<strong>I am running 9 psi now on what I think is a 8.5:1 motor now. My problem is it spikes to 10-11 psi and then settles back down to 9psi. I hope to run more boost soon but don't want to overboost with a spike. What's the best way to control spike?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Make sure you get a good wastegate.
Old Jun 18, 2002 | 05:47 AM
smokinHawk's Avatar
electronic boost controlers are supposed to help control that.
the higher end models. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
when you gonna get your turbo beast dynoed or taking it to the track i can hardly wait to see what power youll put out! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
<small>[ June 18, 2002, 05:51 AM: Message edited by: smokinHawk ]</small>
Old Jun 18, 2002 | 09:52 AM
MIGHTYMOUSE's Avatar
maybe rob or george at tt can help you with wastegate spring selection.. the one you have is a 5psi spring, i have a 3psi spring here (stage one part) that i can send you if you'd like to try it, but the spike will prolly be worse.
are you using the manual controller now or just the wastegate?
if you have the manual controler, hook it between the port ahead of the tb and the wastegate, that way it will see boost sooner.. also maybe mount it in the engine bay, less vaccum hose will be less air inside to compress and a quicker response.
Old Jun 18, 2002 | 01:30 PM
I HAVE THE 7-9 PSI SPRING. i AM USING A BALL/CHECK TYPE VALVE TO bring in boost sooner.
