big turbo for small boost for a little while?
my reason being i dont wanna waste money and upgrade...
id like to have it for my stock motor this winter and then when the funds come build the 408 and big fuel system....
so would the stage 2 (bigger turbo and IC) highflo turbo setup be ok on stock motor with say 225AFRs and a turbo cam?
the heads and cam will swap over to 408...
the only problem is to make sure your wastegate is big enough otherwise your boost will spike. Im planning on running about 12psi starting our and i hope my turbosmart 48mm will be able to control it.
youll have to be ok with its laggy time and not much power per the low boost used.
becuase of soo much boost
