LS1MS STAGE I TURBO
Custom PTE T-63 Turbo - Will support approximately 750fwhp
Custom Aluminum Spearco 1180cfm Superflow Intercooler - supports 1000+fwhp
HKS Wastegate
Custom Pre-Formed Silicone Intercooler piping - Lightweight, durable, and heat dissipating. Choose your color: Black, Red, Blue, Yellow
Custom 304 Stainless Turbo Manifold - 1 3/4" primary tubes / 2 1/2" Log
New 2002 Factory passenger side ported exhaust manifold - ($125 credit will be given should you choose to use your own manifold and port it yourself)
304 Stainless 2 1/4" rear exit crossover pipe
304 Stainless 3" Downpipe
Stainless Aircraft-Quality Constant-Torque Hose Clamps
MSD 8.5mm Plug Wires
85mm High Flow Calibrated Mass Airflow Sensor
Custom In-Tank Quiet-run High Flow Fuel pump assemblies
Balanced and Flow Matched 37lb/hr Injectors
Custom PCM Reprogramming
<img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The only thing i am adding is the HKS BOV <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
<small>[ June 27, 2002, 06:07 PM: Message edited by: 2K2T/A ]</small>
are you asking for engine build up info?
it would be totally fine with the all stock motor.. maybe some better valvesprings but thats it.
drivetrain will need a bump.. rob will reccomend a spec clutch (thats what i run)
the stock rear may last a while unless you drag the car.. then you will notice that you need to invest in a 12 bolt or equivalent promptly.
<small>[ June 27, 2002, 09:53 PM: Message edited by: MIGHTYMOUSE ]</small>
