Calling Harlan...Turbo Question
Compressor wheel data (not sure on compressor housing dont have any yet): Compressor housing inlet diameter 2.75" outlet diameter 2.25"
Wheel Trim = 56
Wheel diameter = 2.09/2.80
Maximum compressor flow = 44 lb/m (each)
Turbine/housing data:
Turbine trim =76
Turbine housing A/R = .86
Turbine diameter = 1.85/2.12
Housing size corresponds to a T28 5 bolt design with integral wastegate
Hope that helps some, Gary
That's them. I actually didn't have them modified. Just rebuilt. I was not comfortable with the amount of "wobble" that had developed in the bearings.
You gotta pick another turbo before we can compare <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Pick a turbonetics any turbonetics, actually they have some nice stuff. You can even get ball bearing turbos from them now and prices arent to bad.
Gary
Push them for all thier worth <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
The guys that cored my old CHRA's had a few pairs from Lingenfelter that they were experimenting with at the time. Seeing how much wheel they could get in them. They said by the time i needed more they'd have a handle on it.
I know for sure i had sufficient oil supply, so my guess is too much abuse from compressor stall. They had a little more than normal axial play in the shaft, but alot of wobble as far as i was concerned. any is too much, and i wasn't about to send compressor wheel into my new motor.
If it comes to it, i may step up to a pair of t60's. Compressor housing is about the same size externally, but the exaust side more what i'm after.
but then again, the 2535's are just perfect for a certain truck i know and a t88 would fit nicely in the car.
decisions, decisions <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
