Need help with a supercharger
Old Jul 23, 2002 | 01:15 PM
crappys nxmaro's Avatar
Default Need help with a supercharger
I installed a friends supercharger the other week its the powerdyne 6 lbs. unit. Now when we rev it in neutral or run it, it will like shudder when we let off the gas like it is gonna dye big time. IS that because he doesnt have a BOV. also he was shooting the dipstick out. He since then has got headers and 3" back except for the cat, We also put a breather on the oil cap. Should he have a problem with crankcase pressure now.
Old Jul 23, 2002 | 01:57 PM
Blackbird's Avatar
Default Re: Need help with a supercharger
never heard of the shuddering problem. can you be more descriptive?
put a checkvalve in line with the pcv to prevent the pressurization
also remove the line that goes from the passenger side valve cover into the tb from the tb and put a filter on the end of it and hang it down in the fenderwell or something of that nature.
I have zero problems with crankcase pressure this way.
the kit does have a bypass so make sure you have that installed correctly and a good vacum source going to it.
