? installing autometer gauges
Old Oct 7, 2005 | 12:15 PM
nasty ss's Avatar
Default ? installing autometer gauges
I am installing my electric fuel pressure gauge and boost gauge in my 02 z06 and had a few questions. I want to wire them so that when I turn on the headlights the backlights in the gauges come on. I would prefer them to work with the dimmer if possible. Does anyone know which wire to run them off of in order to do this? Also is there a pre-existing hole for me to pass the wires through the firewall or will I have to drill one? If so any suggestions on where to drill the hole?
Thanks!
-matt
Old Oct 7, 2005 | 02:29 PM
Deckhand's Avatar
not sure about the hole, but in my 02 silverado .. behind the light dimmer, there is a lime green wire that I tapped off of for my Cobalt gauge. It illuminated the gauge with the headlights, and dimmed also.
Old Oct 7, 2005 | 03:34 PM
Bad30th's Avatar
I drilled a hole in the driver firewall behind the brake pedal under the carpet, used some touchup paint to prevent rust and put a rubber grommet in it to protect the wiring, and siliconed it closed after I ran the wiring. If you want to run over to the pass side there's an existing hole where the PCM wiring harness runs through the firewall.
I tapped into the stereo illum wire for the illum on the gauges.
I have AutoMeter Cobalt boost and trans temp gauges in the driver A/C vents.
Rob (Bad30th)
Old Oct 7, 2005 | 06:24 PM
nasty ss's Avatar
Thanks for the replies. I am trying to figure out the illumination on a vette. I am afraid that if I tap the wire it will see too much of a draw. If anyone has any insite please advise me.
Thanks!
-matt
Old Oct 7, 2005 | 09:56 PM
terry s's Avatar
Thanks!
-matt
You can't just tap the existing dash light circuit. I will get back with more info. PM me if I forget.
Old Oct 7, 2005 | 10:43 PM
terry s's Avatar
Check this out. I just put one together last week.
http://z06vette.com/forums/showthrea...ghlight=dimmer
