how much boost can I run
With stock crank and rods/ forged dished pistons, how much boost can I run safely
I'm planning on new main studs, rod bolts, and head studs too.
anything else I need to upgrade?
well I'm planning it, so all of that is still in the planning stages,
I'm thinking stock cubes (maybe a clean up hone)
T70, or T76 turbo
Fuel system: don't know....whatever it takes
T70, or T76 turbo
Swap out the rods while you are at it, and you can run 14 psi without any problems with the stock crankshaft. Callies compstar rods aren't expensive, and we have never had a rod failure with them. Bob
