I need information
Old Aug 8, 2002 | 01:00 PM
10thanvhawk's Avatar
Default Re: I need information
I take it this is the 3.2 ?
If so I have the same and do not see more than 6-7 PSI. Being that PSI read on a meter is based on pressure due to possitive CFM boost and back pressure within a system, you may never see the 9psi read on the meter, the more efficient the engine is the less PSI you will read due to "less backpressure". I used to read a couple pounds more when I didn't have headers etc.. check you belt for slippage. Also be sure that your PSI lines are tight etc. ANY leak will cause a lower number.
Old Aug 8, 2002 | 01:09 PM
PewterUltraZ00's Avatar
I have already tightened my belt and checked for leaks and it still only reads 5psi. Also I am only hitting a 12.2 at the track. What are you hitting.
Old Aug 8, 2002 | 08:52 PM
2000silverbullet's Avatar
What other MODS do you have besides the charger.
Old Aug 9, 2002 | 12:48 AM
Default I need information
I have installed a 9psi pulley from procharger and I am only getting 5psi out. What could be wrong. If anyone knows let me know. Thanks.
Old Aug 12, 2002 | 02:42 PM
ls1formula99's Avatar
Need to know if you have headers, cam, or if its stock? The answer above about the pressure is correct, I have headers and a cam and the 3.0 pulley and I am seeing only 9lbs.
