Ed Wright tuning with Procharger?
Old Aug 20, 2002 | 12:27 AM
ssracerx2's Avatar
Default Ed Wright tuning with Procharger?
Does anyone use his programming with a Procharger? I am going with 7lbs, 38# injectors, and inline fuel pump. If so did he get it right the first time or were there adjustments to be made? Thanks Rick
Old Aug 20, 2002 | 02:11 AM
SuperSport2000's Avatar
Default Re: Ed Wright tuning with Procharger?
He did my car and it runs pretty good. Tunning is setup on the safe side. Overal I am happy with his work.
-jasen
Old Aug 20, 2002 | 06:27 AM
cablebandit's Avatar
get ls1edit and do it yourself. You ought to be able to just about copy someone elses tune as there are lots of vortech kits out there. You will always be tied to Ed as he locks the computer after he tunes it, Want to add a little more timing or maybe you change injectors...150 bux more to ED...
Old Aug 20, 2002 | 09:14 PM
ssracerx2's Avatar
Good point CableBandit. Will the car run with a stock computer after changing injectors and fuel pump? I would imagine it would but it would be super rich like 9 or 10 to one A/F ratio. What do you guys think?
Old Aug 21, 2002 | 06:40 PM
instigator74's Avatar
Don't go with ed wright ,i've sent mine back 3 times now and it's stll running rich.I would go with the edit.It's not worth the hassel.
shane <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Aug 21, 2002 | 08:11 PM
it will run but very rough as it will be wayyyy too rich.
Old Aug 27, 2002 | 01:15 PM
1LEThumper's Avatar
I sent mine to Ed about 3-4 times and it still wasn't running right. I just started over pretty much doing it myself. His wasn't really that close at all.
