Getting closer - new times
Old Sep 9, 2002 | 01:26 PM
rod442's Avatar
Default Getting closer - new times
For those that do not know, the car is a 2000 formula 6 speed. Stock motor with springs, retainers, pushrods, and injectors 42#. Incon TT kit at 8 psi, no cats and a loudmouth exhaust.
Suspention consists of QA1 shocks F+R with the frt drag springs, SLP ph bar and Metco LCA's w. relocation brackets. Rear is a DTS 12 bolt with 3.73's.
Thanks Harlan for the valve and the AWESOME 2 step. Car would not be able to launch the way it does without it.
Got the 2 step working. New DS in, and turned it up to 8psi.
Made a couple of 1/8th passes to make sure it would run good. so I didn't get booted for an 11.9 lol.
drop the tire pressure to only 18 psi, set 2 step to 5500 and get ready. Car STILL has stock torque arm, sway bar hooked up, and weighs 3850 with driver.
Do a decent burnout in the box, and pull up to the line. Set the 2 step, and rev it up. lights come down, and come off the clutch. Felt like getting asspacked by a freight train.
RT 6.10
60' 1.537 !!!!!!!
330 4.644
1/8 7.190
mph 97.82
1000 9.389
1/4 11.218
mph 123.77
Weather was even crappy, 70 degrees at 9pm at night with almost 100% humidity. wait for 45-55 degree weather.
Now I need to bleed the clutch good. Sometimes pedal doesn't return due to cooked fluid. Get a 01+ intake, timing fixed (still not done), and lean it out some. Remove swaybar, backseat, and run 10 psi.
10.8x here I come.
BTW, if you're wondering about the new title; I was hoping to at least get a few responses <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> . lol
<small>[ September 11, 2002, 05:23 PM: Message edited by: rod442 ]</small>
Old Sep 12, 2002 | 05:39 PM
rod442's Avatar
Default Re: Getting closer - new times
gee, not even 1 response. lol I guess maybe I should have posted this over on the mustang board.
At least there someone would have at least ragged on me about bs'ing and called me a liar <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> .
Old Sep 12, 2002 | 05:54 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Lol Good time man. you clutch people once hooked get some good times. I wish I could do a 1.5
Old Sep 12, 2002 | 06:01 PM
Cool28's Avatar
Man you were moving in the 1/8th.
Old Sep 12, 2002 | 06:03 PM
Black LS1 T/A's Avatar
Moderator
Good blow-by-blow...
GREAT times!
You are SOooooo close to the 10's. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 12, 2002 | 06:51 PM
cablebandit's Avatar
Hell yeah!!! Already faster than my best times. I bet the 1.5 60' was a blast!! What kinda boost are you building on the 2 step? Have you dynod? 3860 is pretty heavy....must be making great power to run that. If I don't work this weekend, i want to try and better my 11.27......on the stock rear <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Sep 12, 2002 | 07:26 PM
truck's Avatar
All on a stock motor! How long have you been running this setup? I am very curious on how strong these motors are.
Old Sep 12, 2002 | 08:06 PM
rod442's Avatar
Ahh, finally some comments. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Cable, I have only played with the 2 step a few times. with a 1.5 60' snapping my head back; I really didn't get to see what the boost was at or what it came up to. Harlan wanted to know the exact same thing. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yeah, 3850 IS heavy. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
with 6 psi, it made ~430rwhp /445rwtq at 11:1 a/f (stock timing) on a mustang dyno. SAME setup made 477/490 on a dynojet. Previus best was 11.43 at 121.15 on a 1.67 60'. NO 2 step on the launch.
At 8psi and being slightly leaner, since I am running the same fuel map since 6 psi; I bet it makes ~480/500. I should find out in a few weeks.
I had the turbo kit installed at Agostino Racing at about 7000 miles. Car currently has about 27500. So call it 20K on the turbo kit. With a trip to Texas (from Michigan) in there. 1200 each way.
Old Sep 12, 2002 | 08:40 PM
Good run. I love that 60' my previous best was a 1.70 dumping the clutch at 5500...we'll see how the 2 step does. I WAS making 5 psi at 4000 on the 2 step but now i have a leak...think i cracked the manifold <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> Gonna run it anyway. Tho the crack has made a cool backfire at night where i actually saw the light from the flame out the back. What kind of timing are you running?
Old Sep 12, 2002 | 08:41 PM
supersp0rt's Avatar
i would be cautious by keep up-ing boost. get greedy and itll go boom...but regardless...very perdy times!
Old Sep 12, 2002 | 09:32 PM
DaveSchott's Avatar
I'm glad to hear you got it mostly sorted out.
Are you using a grainger valve to get to 8 psi?
I've moved to Ohio, still sorting out an electical gremlin, looks like it may be the alternator causing the battery to rapidly discharge.
I've got all the parts now, including a on-board wide-band, all I need is time...
Old Sep 12, 2002 | 09:33 PM
y2khawk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by supersp0rt:
<strong>i would be cautious by keep up-ing boost. get greedy and itll go boom...but regardless...very perdy times!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">He's got room to grow on the boost, but I try to keep him in line <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Watch the boost gauge next time <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
