i could use some advice
Old Oct 11, 2005 | 05:09 PM
DAVID98Z's Avatar
Originally Posted by LSONE
IMO you should keep the ls6 and get a ported TB, the fast has been known to crack when put under a certain amount of boost, and the ohio boys are knocking on the 7 second door with an ls6 intake. If you use the AFR's you can keep the ls6 but if you use the 6.2L your probably gonna need to switch to the ls7/truck manifold.
oh ok thanks for the info i have been thinking about it and i may just start with the d1-sc with some afrs and work my way from there,do u know what the cost of an f1 is though?
Old Oct 11, 2005 | 05:13 PM
LSONE's Avatar
I think its around $2,000 for the head unit, not too sure on that.
Old Oct 11, 2005 | 05:20 PM
DAVID98Z's Avatar
oh ok thanks for all the info and help
Old Oct 11, 2005 | 05:24 PM
LSONE's Avatar
no prob
Old Oct 11, 2005 | 05:34 PM
DAVID98Z's Avatar
no prob
i will probably have my car back in like a week so i will let you guys know how the N/A 402lc did with my curret H/C setup
Old Nov 16, 2005 | 07:43 AM
DAVID98Z's Avatar
Talking Update
well i finally got everything together and on the dyno
and the car made 406rwhp/446rwtq with a unlocked
fuddle 3800tc and 3:73 gears with an 8.5:1 compression ratio but i need to get bigger injectors and ill make some more power but i need to break the motor in a little more before i can do that,but now my problem isnt power its traction lol oh yeah ive decided i will turbo the car but not till some time in the near future
Old Nov 16, 2005 | 08:28 AM
DAVID98Z's Avatar
T T T
Old Nov 16, 2005 | 12:08 PM
DAVID98Z's Avatar
whats the biggest turbo that i could use without having too much lag but still make good power?
Old Nov 16, 2005 | 12:54 PM
98Z28MASS's Avatar
Well you have a good sized stall so youd be able to build boost off the line, so id say on a 402 from what ive heard a T-88 would be good for a 402. I had an informative discussion on this board with one of the members who is building a single turbo 383 and he said he was very close to maxing out his T-76 turbo he was using so a T-88 would be the way to go on a low compression 402. Nice numebrs though NA and im sure they will go up when you get the fuel system and break in time done. What rear are you using right now?
Old Nov 16, 2005 | 01:54 PM
DAVID98Z's Avatar
the car rides like a monster and sounds very mean ive tried to get audio of it but its too loud for my phone to record but so far the stock 10bolt is doing just fine
but i will be upgrading to a 12 bolt soon but i really need some drs cause with my street tires i have to baby out of the whole or ill just spin and get sideways,what kind of numbers do u think i can make on pump gas with that size turbo?my goal is to be around 1xxx if i have to use race gas,i was originally looking at a t-80 but if i can go bigger without lag i will
Old Nov 16, 2005 | 02:16 PM
CHRISPY's Avatar
I would consider a 72cc head with a 4 inch chamber. PRC sells these I believe, you might be able to do an exchange if the parts are new.
An AFR 225 head designed for a 4 inch bore, 72cc and thick decks would be ideal imo
I would go turbo before blower. A T76 or T88 would work wonders
You would have a comp of around 8.3:1 be able to run pump gas and make 700RWHP very easily depending on what turbo you went with.
Check out the forced induction website. They have alot of good information.
Cheers,
Chris
Old Nov 16, 2005 | 02:28 PM
  #32
DAVID98Z's Avatar
You would have a comp of around 8.3:1 be able to run pump gas and make 700RWHP easily depending on what turbo you went with.
Cheers,
Chris
yeah once i go turbo i will be changing my heads and cam,i will probably go with the afr heads and a comprable cam and install my current HC combo on my moms 3rd gen ls1 ,so i shouldnt really have any problems with lag if i went with either turbo?im kind of new when it comes to turbos so sorry if im asking dumb questions does anybody make a kit with a t-88 for a 402?
Old Nov 16, 2005 | 07:43 PM
  #33
DAVID98Z's Avatar
t t t
Old Nov 17, 2005 | 01:04 PM
  #34
98Z28MASS's Avatar
There are a bunch of kits for sale in the FI section. The newest one I believe is Hi-Flo, and I believe their kit is good up to a T-88 turbo. However, 1000rwhp is gonna be real tough to obtain on race gas nevermind pump gas. Like Chrispy said you could def see 600-700 rwhp on pump gas on a forged low comp 402, especially with a T-88, however to get to 1000 rwhp on a 402 youd need a massive turbo, which wouldnt be much fun on the street as it would take very high rpms to get it to spool. On pump gas though at say 13-14 psi you would probably see between 600-700 rwhp, give or take a couple psi. Also you can check out the stick at the top of the Fi section as they have a boosted list for 2005, and this shows everyones setups and the rwhp and rwtq that they have plus their 1/4 times.
Old Nov 17, 2005 | 05:07 PM
  #35
Zach@Texas-Speed's Avatar
For the larger bore setups we've been doing the PRC Stage 3 LQ9 heads. The last set went over 320cfm & made 520rwhp in a 402 with cats!! The 233/239 would be pretty small for a stroker, have you considered the TX Giant 248/254?
Old Nov 18, 2005 | 08:07 AM
  #36
DAVID98Z's Avatar
ok ill be sure to check out that sticky,i was talking with speed inc. and they were saying that i should go with the t-88 and that they can do a similar setup to whats on there shop car that just went 8.95 in the 1/4 and makes 9xx to the wheels with a 370ci motor,so i will probably have them do my entire build from turbo to fuel system and it will al be done with innovative products
Old Nov 18, 2005 | 08:12 AM
  #37
DAVID98Z's Avatar
well i was thinking that but the thing is the motor is going to be turboed and my current h/c combo will be going on my ls1 346 motor which is going into my moms 91 rs camaro so while it would be nice to have that big of a cam i would have no use for it once i go turbo,do u know what i would need to be able to swap my ls1 into a 3rd gen that had a v6
