Vortech Mondo bypass...0-10psi???
I know the valve is shut during WOT and when making boost. So any partial throttle between 0-10psi will be vented into the atmosphere?
Any help is appreciated. Thanks
Andy
Andy
Vortech Engineering recommends that you go no farther in than 4 turns. I have seen units break when screwed in further than 6psi. I run mine like the Vortech Instructions recommended - as far out as will still retain the internal bypass spring under all conditions. Be careful as you can back out the adjustment bolt to the point it disengages, and still have it look OK.
Regards,
Jim
John
Yea John, the idea of an 87' Regal tubbed SBC D1 would have been nice but I personally am liking the look of the 4th gen Camaro. After researching and looking at KP's and PSJ's setup and ET's, I am liking that route. It costs the same, if not a little less to go with my Camaro as the base since I won't have to "restore" an older gbody. Anyways, I am gathering parts as cash comes in. We'll have to meet up again when you are in PA, I wanna see that car now that the "bugs" are worked out.
Take care,
Andy
