6.0 How much boost
Old Sep 30, 2002 | 07:34 PM
EARTH MOTORS's Avatar
Default 6.0 How much boost
72 chevy truck 6.0 9.4comp head studs 36 lb inj 60-1 turbo 3inch down pipe no cat inter cooled ed wright tune 3.73 rear how much boost is safe 93 gas daily driver
Old Sep 30, 2002 | 11:13 PM
AlienDroid's Avatar
Default Re: 6.0 How much boost
go for 12psi, but might be able to run more on the little 60-1 and you might not be able to get any power above 5500 with that little turbo, I'd go for the t76 if I were you. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> , but watch for knock. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
Old Oct 1, 2002 | 10:41 AM
MIGHTYMOUSE's Avatar
i have to assume you are talking about an ls1 based engine?
your combo is very similar to my old one..
t-60, 9.5:1 36#ers, 3.73 gear, ed wright tuning, and intercooled (turbotech kit)..
i ran as much as 13 psi with no problems but you have more displacement which means you will need more fuel than i did.. make sure you have a fuel pressure gauge and at least a 255lph high pressure pump. (walbro gss340)... this may out-do the injectors so be careful.
the turbo will be running more rpm as well so keep an eye on your IAT's.
also be conservative on timing, maybe 17* max at torque peak.
Old Oct 1, 2002 | 06:04 PM
2002 6.0 4l60e 255 lph pump turb tech manifold modified to fit 72 truck I have fuel pressure ; boost and pyrometor gauges . how much temp is max ; prob installed 3" after turbo
