FI head mods?
Old Oct 6, 2002 | 05:50 AM
phantom meneSS's Avatar
Default FI head mods?
Im pulling my heads of shortly to replace the gaskets with .065" cometic ones and adding a head stud kit in preperation for a Intercooled Autorotor PD twin-screw blower running with a alky/water spray and 10 psi of boost. What would you guys suggest doing to the heads while there off?
Im thinking maybe larger exhaust valves, cutting the seats a bit wider and a mild port job. I also want to unshroud the valves as much as possible as compression will not be my friend anyway.
Any ideas or suggestions would be great.
Im also adding some double valve springs and some 1.8 ratio rockers with the std cam.
<small>[ October 06, 2002, 05:51 AM: Message edited by: phantom meneSS ]</small>
Old Oct 7, 2002 | 03:44 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Default Re: FI head mods?
TTT
